Originalmente inviato da astroroma Ivano dove hai letto delle RX,io ogni tanto metto tra i Preferiti questi Link e regolarmente non li ritrovo....... |
Eccolo astro:
What are the differences between Walkera ESC's? - RC Groups
Discutono anche l'intercambiabilità radio/controller. Da questa frase ho dedotto che non sono compatibili:
It should also be noted that the LTB and LTC ESC main purpose is to operate on the higher signal generated by the 5 in 1 type of receivers Walkera recently released. They operate at a higher mHZ than regular receivers and can not use normal brushless ESC's. Nano Heli developed a converter to allow his flea to operate with those receivers."
