| motore upgrade Dragonfly 36 Vorrei acquistare un nuovo motore per il mio dragonfly 36 perchè monta ancora quello originale, quale kit mi consigliate? 1) Walkera Brushless Motor 380 Model : WK-WS-28-003- Working Voltage : 6-18v
- Speed Constant : 3000 rpm/v
- Dimension : 28mm x 37.5mm
- Shaft Diameter : 3.17mm
- Shaft Extension : 17.5
- Weight : 96g
- With a 15-tooth gear
30A Electronic Speed Controller for brushless motor Model: WK-WST-30A- Sustaining Voltage : 6-17V
- BEC Current : 3.0A
- Continuous Output Current :30A
- Instant Max Current : 50A
- Inside Impedance : 0.0044Ω
- Reversion : Yes
- Low Voltage, Cut Electricity Protection: Yes
- Weight : 32.4g
euro 57. 2) 4200 Outrunner Brushless Motor- Working Voltage : 6-18v
- Speed Constant : 4200 rpm/v
- Dimension : 26mm x 26mm
- Shaft Diameter : 2.0mm
- Shaft Extension : 14mm
- Weight : 35g
30A Electronic Speed Controller for brushless motor- Input Voltage: Li-ion 2-3 cells
- BEC Current : 2.0A
- Weight : 25g
euro 50.
Grazie ciao!
__________________ /**nocomment */ |
