Vecchio 09 novembre 11, 16:20   #3890 (permalink)  Top
urgno
L'avatar di urgno
Data registr.: 20-06-2007
Residenza: dintorni di Venezia
mi pare che qui si capisca meglio:
The R6203SB is a full range RX featuring the standard dual coxial antennas.
The key feature is the form factor, only 22×37x9mm in size.
This RX features 3 normal PWM channels and one S.Bus connection.
As with all other S.Bus RX this one connection allows you to connection up to 18 (16+2) servos.
Last but not least, the “2″ in the part number signifies this RX is also capable of 8.4v power systems (i.e. direct 2s lipo).
2x Prôtos Carbon Stretch FBL:MKS9660 / MKS9670 + BEASTX detti "i gemelli"
Acrobat Shark FBL +BEASTX detto "Emmenthal / Mucca"
urgno non è collegato   Rispondi citando
