Vecchio 03 novembre 11, 20:24   #2985 (permalink)  Top
alexone85
L'avatar di alexone85
Data registr.: 25-08-2007
Residenza: Piemonte
Ciao ragazzi,
vorrei piu trazione a terra per il revino, sono indeciso se prendere il diff centrale normale della traxxas o un nuovo prodotto della hot racing "one way" (allego il testo)
Cosa consigliate:
Hot Racing's Steel Center One-Way Differential for use on the Traxxas 1/16 Mini Revo, 1/16 Rally. #VXS125X
Notes:
This is the hot racing center one-way differential, transfers power to the front differential under acceleration but allows it and the front diff. to "freewheel" while decelerating or braking. unlike a front one-way differential, a center one-way allows front differential action.
FEATURES: steel gear and shaft 6x10mm one way bearing
YOU WILL RECEIVE: one steel center one way diff with pre-installed bearing one steel shaft
comment: one-way mode for racing tight tracks where maximum off-power steering is needed.
This item is intended for these models:
Traxxas 1/16 E-Revo VXL 1/16 Slash/Rally 4WD 1/16 Summit VXL
Grazie mille.
alexone85 non รจ collegato   Rispondi citando
