Vecchio 21 ottobre 11, 18:51   #3056 (permalink)  Top
dicio
L'avatar di dicio
Data registr.: 24-10-2006
Residenza: Milano
Scritto da erazz in data 28 ago 2010 :
I fixed the batt voltage comma and more importantly the InstaCrash... Ahmmm InstaTrim is working properly!
It only updates the state of the 3 primary controls (AIL, RUD, ELE). Throttle is ignored since it has no center.
Need testing badly on this one.
Quindi lo stick del motore non è compreso : PERFETTO !!
Ho trovato anche questo, sempre scritto da lui, dove spiega il funzionamento :
The "instaTrim" takes a "snapshot" of your output channels and compares them with the channels when only the sticks are zeroed. The difference is added to the subtrims.
On that premise, if you hold the stick to one side and push the i.t. button the radio should "remember" the position of the surfaces. What should happen is that after pressing the button, the surface should jump further to the same side. When you release the stick the surface should jump back to where it was when you pressed the i.t. button.
If you want to center the surfaces you would need to hold the stick in the opposite direction and press the i.t. button. Alternatively, you can simply zero the subtrims in the limit menu.
FD
Ultima modifica di dicio : 21 ottobre 11 alle ore 18:55
dicio non è collegato   Rispondi citando
