Originalmente inviato da gracing Hello GMAURO..
Here follows...(i know this is a Heli Forum)...hope you don´t mind...
[IMG] [/IMG]
Best top speed in oval 123km/h
By the way, can i put 3 turns in one tooth, and 4 turns on the other ttoh?
If yes, should they be desphased 90º , am i right..that should give about 3.5 turn? |
My test on 12n8p confirm the calculation with this schema (kv Of turn delta x 1.15 done yy kv...) please test and post your results. Good work.
