Originalmente inviato da gracing Hello GMAURO
I hope everything is good with you.....
i have this motor, the scorpion 4035 in a boat, but i want less heat, and more power....i have 1.8mm wire that i want to rewire...
Check this video : 10S Rigger Portugal - YouTube
But i want to change the Delta winding to YY......
From the link that you sent me the stator dont work in pairs has in normal 12N10P, is this normal?
Mine Motor has 6 turn Delta with 800Kv...If i put 3+3 turn i will have 800*1.15= +/- 920Kv..am i right?
Best Regards GMAURO |
Yes this schema is correct. This is only possible for 12N8P YY. If you rewind with tooth in pair motor don't work because the esc don't found the correct sincronously on "free" fase.
The calculation of Kv is ok.....
Good work and post your result if you whant!
Pics of your boat?
Bye Mauro
