Originalmente inviato da gracing Hello
I´m Portuguese, and can´t speak italian....Sorry!
I have a Scorpion 4035 wich is a 12N8P 6 turn Delta Winding, wich has 800Kv.
I would like to keep the Rpm, or increase it to 900Kv more or less in a YY winding with 3+3 1.8mm turns per tooth...The problem is that all the winding schematic i see in the net is for 12N10P and not 12N8P....Is the winding chematic the same, or it´s different?
Is it possible for a good working motor a YY winding in a 12N8P motor?
Very Best Regards and thanks for your help, everyone!  |
Gerardo.... are you? A new motor ready for rewind?
For find this schema please see the following link
12N8P YY winding schema
The YY winding is possible for all N-P combination (but not with all the same schema), this 12N8P have only a little more difficult to jump with wire from 1° to 4° toot, from 2° to 5° etc..... but with a patience is possible.
But why you whant use this motor for high Kv? for very big wire diameter or only because 8P motor done high Kv?
