cambiando prospettiva..
Ora spero di star meglio e provare a fare un bel cratere..così ricostruisco il tutto e provo i nuovi servi che mi sono arrivati dalla cina.. Li conoscete?
"3x HENGE MD933 + 1x MD922 MG Digital SERVO TREX 450 US"
MD922
Work electric voltage: 4.5V_6.0V
Work temperature: -20 to 60
Speed: 0.07 sec/60 6V 0.09 sec/60 4.8V
Torque: 1.8kg. Cm 6V 1.6kg. Cm 4.8V
Work electric current: 50-150mA
Block up to turn electric current: 550mA
Dead band width: ≤3usec
Weight: 12g
Ball bearing: Metal
Wheel gear: 5 metal gears
Signal line length: 22cm
Specifications:
Operating voltage range: 4.5V6.0V
Operating temperature range: -20C to +60C
Operating speed: 0.10 sec/60C 6V 0.12 sec/60 C 4.8V
Torque: 2.0kg.cm 6V 1.8kg.cm 4.8V
Idle current: 5mA at stopped
Running current range: 50-150mA
Block up to turn electric current: 600mA
Dead band width:≤4usec
Angle deviation: center :<±0.5 degree; angle ±40 degree, error :<±0.5 degree
Weight: 12g
Bearing material: Metal
Gear material: 4 metal gears and 1 nylon gear
Connector wire length: 21cm
