The weatronic® GPS module on board is continuously sending all measured data concerning route, speed, position as well as altitude to the weatronic® 2.4 Dual FHSS transmitter module.
There you can freely define via GigaControl how often and which data should be emitted in your headphones. The device, for example, is able to emit speed and/or altitude over ground or the current position in spoken language.
Moreover the data is logged on the integrated micro SD-memory card, comparable to the mode of operation of a flight data recorder in aviation. With the aid of the weatronic® software GigaControl, the connected GPS-sensor can be set up.
weatronic GmbH - RC components - The weatronic® GPS module
bel giocattolino questo sistema
