che ne dite di questo???
21gram RC Airplane Outrunner Brushless Motor 9 Pole for Mini EP 3D Plane (100-150gram) 100% Brand New
Size: Dia. 28mm x 26mm (not include the shaft)
Shaft Dia: Standard threaded 3 mm Shaft (suitable for GWS props etc.)
Weight: 21g(without wire)
Max Current: 10 Amps (Recommend using the 10-15A Brushless ESC)
Input Voltage: 6-12V suitable for 2 cells or 3 cells Lipo.
KV: 2500 RPM/V
