V1.08(1) online 11Jul11 - contains the following amendments:
1. Spelling changes as lower or upper case letter
. System and Model
MODE - Mode
. Stick Mode MODE 1 : Mode 1 (2,3 and 4)
[Flight Cond]NORMAL : [Flight COND]Normal
NORMAL - Normal
INSERT - Insert
Cond - COND
SET - Set
Thro. - THRO.
[Throttle Curve] : NORMAL - Normal
Info - INFO
NULL - Null
NONE - None
CAMBMIX - CAMB.Mix
Thro.Cut - THRO.Cut
ThroLock - THROLock
- Spectra Pro
Modulat - MODU
Freq Sel - FREQ.SEL
- Timer
DOWN - Down
UP - Up
2. In the V-tail mix, under Butterfly function, Rudder channel is not working in the V1.08(0), in that (+) and (-) mixing value cannot be adjusted, this bug fixed.
3. Spoiler Channel Control with Throttle stick (Mode 1 - J2, Mode 2 - J3), between the direction of Throttle stick and direction Elevator movement are opposite each other under V1.08(0) is fixed.
Ma vale la pena aggiornare per queste piccole correzioni? Mah...
