Originalmente inviato da woodstock101 La cerniera del timone è off-set, in modo da tirare-pull è molto difficile da far funzionare. Non ho flutter, anche in immersioni molto veloce.
The rudder hinge is off-set, so pull-pull does not work well.
I have no flutter, even in high-speed dives. |
the trick is easy! just align horn of pull-pull with the hinge and pull-pull works very well!
however if you do not have flutter with your method it is ok!
