ho mandato
"hy! i need a motor and chinese jade don't ship to Italy. i want to ask when you will update your catalog with the AeoRC ADH50 (C05 New Improved Version) Outrunner Brushless Motor with 11300kv and very important shaft of 1mm. is for an eflite blade mcpx converted brushless and the pinion has a hole of 1mm, so we need your motor!!! please help us.
i put a link to see what we need and on your site is not present
Brushless Motors & Esc
The shaft in 1mm diameter because this can have stocked Walkera pinions used on it. 4#3B is 1mm dismater.
ADH50 (C05) is new improved version. It is lighter and smaller.
Shaft (Diameter): 1mm (Stock Pinion Can be Used)
Mounting Screws are included.
Thrust: 90g
KV: 11300
Item No: HM-C05-BLMotor
SOLD OUT
please update your site, some people need that motor. eflite mcpx was sell a lot and a lot of people will go brushless and your motor with 1mm shaft is the perfect solution.
i need to order one or two from you so please update!!!"
dobbiamo essere piu persone che mandano email. forse si stuffano e lo metono in catalog(sito)
loro email :
aeotech@aeorc.cn ![:fiu:](/forum/images/smilies/fiu.gif)
