@Lift mi ha risposto aoerc.cn dicendomi questo...
gli ho mandato un e-mail per il motore che avevi mezionato tu
AeoRC ADH50 (C05 New Improved Version) Outrunner Brushless Motor
The shaft in 1mm diameter because this can have stocked Walkera pinions used on it. 4#3B is 1mm dismater.
ADH50 (C05) is new improved version. It is lighter and smaller.
Shaft (Diameter): 1mm (Stock Pinion Can be Used)
Mounting Screws are included.
Thrust: 90gKV: 11300
Aeorc.cn mi ha detto:
Hi,sir
Our AEO ADH50 motor now is called "C05M',you can buy on our website:
C05M - Motor Aero Electronics Operations - AEO Tech
in un altra e-mail mi ha detto questo
Sorry,the shaft diameter is 1.5mm,not 1mm.And the thrust up to 80g
You can check the website link:
C05M - Motor Aero Electronics Operations - AEO Tech are test data for reference
Mi domando tu non hai preso quello con l'albero da 1 mm? ADH 50
