dimenticavo...la concorrenza non si esaurisce con il DL30:
http://www.baronerosso.it/forum/aero...3-benzina.html
2-cycle oil
Ignition Battery: 4.8-6.0V NiCd or NiMH, 6.6V LiFe or 7.4V LiPo pack
LiPo battery requires voltage regulator
Propeller: 18x10-12, 19x10, 20x8-10, use 18x8 prop for break-in
SPECS: Displacement: 2.013 cu in
Bore: 1.417"
Stroke: 1.276
Weight: Engine, 34.57oz (980g)
Muffler, 4.9oz (140g)
Ignition: 3.9oz (110g)
RPM Range: 1,800 - 8,000
Compression Ratio:
Gasoline/Oil Mixture: 30:1 - 50:1
Replacement Spark Plug: NGK CM-6 or Denso U20M-U
