Sto collaudando il mio protos v-stabi fatto i settaggi e in overing sembra tutto ok ma nel volato mi da questi 2 errori :
1:21 Elevator Sensor shows
no actual Signal
This is an plausibility check. If the Heli starts to vibrate, this shall at least have effect to all sensors. If
one of the Sensors do not show the Signal, it may point to a specific problem, not necassary with this
sensor, but a general problem.
1:26 High Vibration Level The control loop suffers from a high vibration level, that starts to render the sensors blind. Save flying
is possible, but
le vibrazioni ok devo risolvere in qualche modo ma quello dell'elevatore a cosa puo dipendere?
grazie Fausto
__________________ |
