11 maggio 11, 00:51
#184 (permalink)
Top |
Data registr.: 19-01-2005 Residenza: 33170 e dintorni
Originalmente inviato da flylivio vi metto una foto che mi ha inviato il venditore pochi minuti fa sulla mia email con la conferma dell' ordine, ho preso la versiona con la flybar , ecco la scatola cosa include,
Trex 600E Pro Super Combo Includes:
T-REX 600E Pro Kit Set X1
Aluminum Tail Boom X1
600D Carbon Fiber Blades X1 set
600MX Brushless Motor X1
GP780 Head Lock Gyro X1
DS610 Standard Servo X1
DS650 Specialized Servo X1
Castle ICE HV 80 Brushless ESC X1
6A External BEC X1
Trex 600E Pro Super Combo Features:
Brand new all metal high precision and high rigidity main blade assembly, providing 3 positive/negative deltas and numerous Bell & Hiller mixing ratios.
The frame utilizes 2mm carbon fiber plates of the highest spec.
Innovative sliding battery tray tails imbedded into the 3K side frames, with patented spring loaded latching mechanism, allowing for quick battery access as well as battery protection.
Top mounted motor base bringing the motor's center of gravity closer to rotating disc, improving 3D agility.
Utilizes highest spec CNC Module-1 helical main gear, with highest load tolerance and lowest noise.
Utilizes direct link CCPM swashplate control system to enable direct and fast control response. Specialty designed anodized CDC servo horns are not only visually pleasing, but are extremely rigid.
Heatsink embedded into motor mount for effective cooling of motor.
The most optimal motor pinion ratio and tail gear ratio to achieve the most efficient power output.
High quality 5mm carbon rod and CNC metal tail scissor control arms are used in rudder control system.
Additional radial bearing is added to the one way bearing block to ensure smooth rotation, and eliminate jammed one way bearing. | eee?
questo motore non va a 12S.
boo.
Trattiamo bene la terra su cui viviamo: essa non ci è stata donata dai nostri padri, ma ci è stata prestata dai nostri figli
