Power your receiver and servos with the baddest of UBEC power solutions.
The all new Turnigy 7.5A UBEC is an advanced switching DC-DC regulator which will supply a constant 5A or more with short bursts of up to 7.5amps. The Turnigy UBEC plugs into a 3 - 10 Cell Lipoly pack and supplies a constant 5 or 6v to your receiver.
The system includes an anti-short circuit and overheat function with a thin metal shield cover, reducing noise Also included is an Output filter to reduce noise, an on/off switch and a step down regulator adapter.
Chip efficiency is 92%.
If you have a mid sized plane, with standard servos and want a solid UBEC which wont quit. This is an excellent option.
Potrebbe essere il primo... ma se invece fosse il secondo ???
