info ufficilai hirobo
Length: 837mm 32.95 in
Width: 144mm 5.67 in
Height: 281 11.06 in
Weight: 1600g 3.5lbs
Rotor Dia: 955mm 37.6 in
Linkage: Push Pull 120 CCPM
Drive train: DTDS gear set, belt drive to tail
RPM: 1800-1900 hover
2600 for aerobatics on 4S power
Main Blade: 425mm, 50g Symmetrical FRP
Tail Rotor Dia: 160mm 6.3 in.
Tail Rotor blades: 54mm
Rotor Head: All metal SZ-M, Swash, washout, mixing levers all metal
Main Frame: Carbon Fiber
Gear ratio: 3.9:1:4 for 4S, 3.61:1:4 for 3S.
Main gear: 94T
Pinion Gear : 24t ( for 4S set up), 26T pinion for 3 cell, both included in kit.
Motor: 890KV outrunner with 5mm shaft and attached fan req'd
Speed Control: up to 4 cell lipo, 60A-80A, BEC req'd, Governor suggested
Battery: 4s1p 3000-3700 or twin 3 cell 2100's in parallel okay.
Gyro: 401 with 9650 servo recommended, 9254 too big
Servos: Futaba s3102 or similiar, standard servos too big.
Receiver: PCM only, PPM or FM receiver not recommended
Flight Performance: 10mins normal, 6min 3D
Other: Blade support included for storage.
Only the kit with no electronics will be initially released. We should have delivery in June 2006. A full version with battery, special charger, speed control and motor will come later in the season.
Street cost anticipated at US $600-650.00
First shipment almost sold out. If you want one, order now!
