Originalmente inviato da steely3d questo valore"90A/150A(5sec)" è l'assorbimento per pochi secondi(di picco)????? |
* The 600MX motor incorporates radial fan in its end bell, creating powerful airflow to dissipate heat. Tweaks to motor design and reduction in weight not only contributes to dramatic power increase, the high efficiency cooling system enables cooler operating temperature during and after flights when compared to motor of previous generation.
* The 600MX motor armature had a special balance adjust to improve the serious shaking problem that other tiny motors have.
* Maintenance free, high torque, high efficiency, stable and quiet.
* High-speed ball bearings, powerful magnetic outrunner rotor.
* Suitable for Trex 600 helicopters.
Specifications:
* Input voltage: DC 11.1V-25.2V 3-6cell Li-Po
* Max continuous current: 90A/150A(5sec)
* Max output power: 2000W/3000W(5sec)
* KV value: 1220KV
* Dimension: Spindle 6x45x59mm
* Weight: 320g (prox.)
Included in box:
* Socket screw(M3X10)X2
* Washer(3X8X1)X2
* ALIGN standard 4mm gilt terminal x 3set
Il 150A penso si riferisca alla corrente di picco che ha il motore in partenza..
