| allora
allora da quello che si legge, i castle creation dovrebbero avere un ritardo nella risposta del gas
che deve essere corretto o via firmware od altro
Ciao allora dai test di MrMel ecco come impostare il CC
CURRENTLY NOT OPTIMAL
Castle Creation
External programmer required: Yes (purchased separately)
Setting for optimal performance: Airplane mode, Fixed endpoints, high throttle response.
Notes:
Balance between Gain in VBar governor and throttle response.
ICE: Use internal logging to make sure you do not hit 100% PWM (full throttle too often for optimal performance)
Overall:
Has delay on throttle response which in effect causing less performance compared to the others, Castle is aware, they will come out with an FW update.
quindi ogni suggerimento e' apprezzato
