Allora, forse continua a non capire io....
Ma i due esc linkati nella prima pagina del 3d supportano i sensori....
Di seguito le caratteristiche...
Specification
Model: XERUN-150A
Dimension: 58mm(L) x 46.5mm(W) x 35mm(H)
Cont. / Burst Current: 150A / 950A
Resistance: 0.0002 ohm
Suitable Motor: Sensored and sensorless brushless motors
=>4.5T, KV<=3000 (Works with 4S Li-Po), =>6T, KV<=2400 (Works with 6S Li-Po)
Battery: 6-18 cells NiMH or 2-6 cells Li-Po
BEC Output: 5.75V/3A Switch mode built-in BEC
Cooling Fan Working Voltage: 5V, max. 8V (The fan gets the power supply from the built-in BEC)
Suitable Model: 1/5, 1/8 on-road, off-road, monster, Super powerful applications
Features
Compatible with all sensorless brushless motors and most of sensored brushless motors such as LRP, SpeedPassion, Novak, Etc.
Seamlessly change to sensorless working mode when the sensor cable is broken.
Excellent start-up, acceleration and linearity features.
Built-in switch mode BEC has a powerful output to supply all the electronic equipments.
Firmware can be updated through an USB adapter on the advanced LCD Program Box (Optional equipment).
Specification
Model: EZRUN-150A PRO
Dimension: 68mm(L) x 55mm(W) x 45mm(H)
Cont. / Burst Current: 150A / 1080A
Suitable Car: 1/5, 1/8 on-road and off-road cars / trucks for competitive race
Suitable Motor: =>3.5T
Battery: 6-18 cells (NiMH or NiCd) or 2-6 cells (Li-Po)
BEC Output: 5.75V/3A of Switch mode built-in BEC
Net Weght: 150g (without wires)
Features
Compatible with all sensorless brushless motors and most of sensored brushless motors such as Novak, LRP and Feigao Etc.
3 running modes (Forward only with brake, Forward/Reverse with brake, Forward/Reverse immediately).
4 steps of maximum reverse force adjustment.
Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
9 start modes (Also called "Punch") from "very soft (Level 1)" to "very aggressive (Level 9)".
Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection / Motor blocked protection.
8 steps of timing adjustment by software. You can even use this programmable item to adjust the timing value even for a sensored brushless motor. (Traditionally, you must turn the rear cover of the motor to change the timing value for a sensored brushless motor).
Firmware can be updated through an USB adapter (Optional equipment).
Splash proof and dustproof.
