qualcuno ha provato il firmware
The beta update doesn't do too much. Stick calibration works. Not much need for it unless maybe you drop your transmitter. ha The 12+2 channel works. There is suppose to be a new user menu where you can choose ten functions that you use the most but does not seem funtional on the beta. According to the German website there is suppose to be an additional way to select rates but that function also seems inop. Other than that its about it. Its a good uprade for free.
Having been a dedicted Futaba user for a long time the retract switch has always been on the top front left switch, position SE. I don't want to use SF.
I am too old and set in my ways. Futaba needs to change that switch option-- not me!
