Vecchio 08 gennaio 11, 18:05   #18 (permalink)  Top
alvise
L'avatar di alvise
Data registr.: 25-01-2009
Residenza: Venezia
Per le differenze copio e incollo dal thread di Rc Groups del progettista:
The main changes are:
- two piece wing
- new airfoil (wider speed range)
- 3 wing options: Poly with no ailerons, 1,56m span and 1,72m wingspan with ailerons
- longer cockpit to allow installation of lighter Li-po cells and lighter BL motors
- reinforcments in the fuselage/wing joint to prevent fuselage damage on unfortunate landings
- elevator and rudder servo tray
- optional removable horizontal tail
- simplified wing tip
- simplified transition from root wing trailing edge to the fuselage
Guppy MK 2. - RC Groups
Per le ali farò la versione da 1,72 AA con alettoni
alvise non è collegato   Rispondi citando
