23 dicembre 10, 12:21
#1622 (permalink)
Top |
Data registr.: 10-03-2010
Originalmente inviato da cbrseicento domanda ma tra il firware del v1 e quello del v2 che differenza c'è? | Copio/incollo dal forum beastx: Ok, let's see what's new to the user:
Setup-Menu:
Swashplate - Frequency Settings (Hz): 50, 65, 120, 165, 200 + User defined (50-333)
Tailservo - Frequency Settings (Hz): 50, 165, 270, 333, 560 + User defined (50-560)
Swashplate Mixers: mechanical, 90°, 120°, 140°, 140° 1:1, + User defined (freely configurable)
Parameter-Menu:
Steck Deadband: 5 predefined sets from low to high + User definable
Tail Torque Precompensation: off - or user definable
For all the stuff, which is user definable, you still need an application for your PC which will NOT be available on the 24th.
Receivers:
- The standard receiver is still supported
- ONE Spektrum Sat is connectable with an additional cable (check your dealer for that), as discussed only for 250 and 450 class!
- PPM composite signals supported
- Futaba S-BUS is now supported, too
The receivers can be easily setup at the device, no PC needed at all. BEASTX Development Team |
