Originalmente inviato da paxlydj |
basta leggere....
Turnigy High Density light strips come with 60 LEDs per meter!!
LEDs are arranged
in sets of 3, you can cut the strip and make new strips or extend strips to make any combination of 3 lights!
Features:
Comes with adhesive tape backing for easy mounting
Flexible enough to be bent at any angle
Easy to use. Just peel and stick!
Large voltage input range up to 12V DC! (Great for 2-3S Lipoly)
i led vanno 3 a 3, quindi ne puoi mettere 3 - 6 - 9 -12, e ogni "terna" va alimentata a max 12v.
dovrebbe essereci sul circuitino stampata una forbicina di dove puoi tagliare la striscia
