I giri non li ho misurati, ma facendo le prove di assorbimento a terra ( quindi spingendo al massimo ) non ho mai avuto problemi.
Il motore è:
E-Flite Power 25 BL Outrunner Motor, 870Kv
Type: Brushless outrunner
Size: Replacement for 25-size glow engine
Bearings or Bushings: One 5 x 14 x 5mm Bearing, and Two 5 x 11 x 4mm Bearings
Wire Gauge: 14
Recommended Prop Range: 11x8 to 14x7
Voltage: 1216.8
RPM/Volt (Kv): 870
Resistance (Ri): .03 ohms
Idle Current (Io): 2.40A @ 10V
Continuous Current: 32A
Maximum Burst Current: 44A (15 sec)
Cells: 3S-4S Li-Po or 1014 Ni-MH/Ni-Cd
Speed Control: 4045A brushless
Weight: 190 g (6.7 oz)
Overall Diameter: 35mm (1.40 in)
Shaft Diameter: 5mm (.20 in)
Overall Length: 54mm (2.10 in)
e l'elica una APC E 12X8 come da manuale
__________________ Gogiamma |
