It is what it says - Super Simple
Here are the instructions:
Always start with throttle off, except when programming - then at full throttle!
Remember to check for channel reverse!
1. Turn on TX.
2. Set full throttle
3. wait for the beeps - 3sec after the first initial beep: (move throttle to off position during pause to select setting)
3a. beep, pause, beep - Li-po (cut-off 3v per cell)
3b. beep, beep, pause, beep, beep - Ni-Mh (cut-off at 60% of starting voltage)
3c. beep,beep,beep, pause, beep, beep, beep -toggle brake enable/disable
Glad to have it, will by more. Cheers.
Semplice, segli il tipo di celle, la tensione la sceglie lui ! Umberto
