Vecchio 04 agosto 10, 14:20   #23 (permalink)  Top
alienholograma
L'avatar di alienholograma
Data registr.: 19-06-2009
Residenza: Risano_Ud
Scorpion HK-3026-880
scusate se rompo ankora...
ank questo sarebbe un chiodo come motore?
SPECIFICATIONS
Stator Diameter 30.0 mm(1.181 in)
Stator Thickness 26.0 mm(1.024 in)
No. of Stator Arms 12
Magnet Poles 10
Motor Wind 10 Turn Delta
Motor Wire 14-Strand 0.25 mm(31 AWG)
Motor Kv 880Kv RPM/Volt
No-Load Current(Io/10V) 1.93 Amps
Motor Resistance (Rm) 0.026 Ohms
Max Continuous Current 52 Amps
Max Continuous Power 1450 watts
Weight 199 Grams (7.02 oz)
Outside Diameter 37.5 mm (1.476 in)
Shaft Diameter 4.98mm (0.196 in)
Body Length 48.4 mm (1.906 in)
Overall Shaft Length 74.2 mm (2.921 in)
Max Lipo Cell 8s
alienholograma non รจ collegato   Rispondi citando
