Ragazzi sto settando il nuovo ESC sapete dirmi che head speed avete sui vostri titan ....
a me viene fuori questo
Voltage for this calculation (avg):3,6815/cell with a total of 11,0445
Nominal voltage: Spoolup RPM 100% throttle no governor (11,1v): 3559
Avg RPM you will see with 100% throttle and no governor: 3373
Max normal bogging applied you will see RPM at: 3010
(this number should be the minimum if your motor & battery is up for the challenge)
ma mi sembra un po´altina.....
__________________ Mini Titan 325 SE | T-REX 250SE| The monster..... Trex 700 LE ![:sbav:](/forum/images/smilies/sbav.gif)
_______________________________ Futaba 10CG 2.4G FASST |
