Vecchio 09 giugno 10, 15:16   #17 (permalink)  Top
hanz1979
Data registr.: 25-01-2010
Residenza: viterbo
allego i dati dei motori:
SPEED 900 BB Torque 12 V
Nominal voltage 12 V
Operating voltage range 6 ... 40 V
No-load rpm 6500 min–1
No-load current drain 1,1 A
Current drain at max. efficiency 8 A
Current drain when stalled 54 A
Max. efficiency without gearbox 71 %
Length of case, excl. shaft 85 mm
Diameter 51,5 mm
Free shaft length 15 mm
Shaft diameter 6 mm
Weight 645 g
hanz1979 non è collegato   Rispondi citando
