allara ti vedo ferrato in materia, mi dai un consiglio?
ho preso un brushless
A20-20L 1050KV RC Airplane Outrunner Brushless Motor
· 100% Brand New
· Size: 28.00mm (Dia.) x 27.00mm (L)
· Weight: 61g
· Shaft: 3.00mm (Dia.) x 14.00mm (L)
· K/V: 1050
· Working Current: 6A 15A, Max. 19A
· Battery: 3 cells Lipo batteries
· Prop mount and gold plated connectors included
ed un regolatore:
Tower Pro 15A Brushless Motor Electric Speed Controller
· Size 42 x 25 x 10mm
· Weight 20g
· Continuous current limit 15A
· Maximum current limit 18A (within 5 second)
· Input voltage from 7.2V to 12V
· Suitable for Nicd, NiMH and Lipo batteries
· Selective cut-off voltage at by a jumper switch
· Can be programmed to switch the brake ON / OFF
· Number of FET = 12 pieces
· High rate PWM 8K
· BEC 1.5A
· Self-adjusting throttle range
· Suitable for JR/Futaba/Hitec/GWS
· An English operation manual is included
che batterie ci devo comprare? quante volts, quante mha, e quante celle ?
grazie
