Discussione: primo aereomodello
Vecchio 24 marzo 06, 09:51   #11 (permalink)  Top
duca75
L'avatar di duca75
Data registr.: 23-09-2005
allora, ho preso questo motore:
A20-20L 1050KV RC Airplane Outrunner Brushless Motor S http://members.sparedollar.com/resiz...4.JPG&size=600
· 100% Brand New
· Size: 28.00mm (Dia.) x 27.00mm (L)
· Weight: 61g
· Shaft: 3.00mm (Dia.) x 14.00mm (L)
· K/V: 1050
· Working Current: 6A – 15A, Max. 19A
· Battery: 3 cells Lipo batteries
· Prop mount and gold plated connectors included
e questo regolatore:
15A Brushless Motor Electric Speed Control Controller
Click Photos to Enlarge
http://members.sparedollar.com/resiz...1.jpg&size=140http://members.sparedollar.com/resiz...2.jpg&size=140 Description Tower Pro 15A Brushless Motor Electric Speed Controller
· Size 42 x 25 x 10mm
· Weight 20g
· Continuous current limit 15A
· Maximum current limit 18A (within 5 second)
· Input voltage from 7.2V to 12V
· Suitable for Nicd, NiMH and Lipo batteries
· Selective cut-off voltage at by a jumper switch
· Can be programmed to switch the brake ON / OFF
· Number of FET = 12 pieces
· High rate PWM 8K
· BEC 1.5A
· Self-adjusting throttle range
· Suitable for JR/Futaba/Hitec/GWS
· An English operation manual is included
che batterie devo comprare? che voltaggio?
ne ho trovate da 11.1vt 1800mha ma c'e' scritto 10C, che vuole dire 10 celle? bo!!!!!!!
Ultima modifica di duca75 : 24 marzo 06 alle ore 09:57
duca75 non è collegato   Rispondi citando
