Quick Flashing: Gyro is initializing after powerering up
LED On: Gyro is in AVCS mode
LED Off: Gyro is in the normal mode OR there is no power to the gyro Slow flash: Power is on, but there is no signal from the transmitter
Double Flash: Conflicting neutral position between position saved in gyro and neutral message received from the receiver in the AVCS mode OR the bell crank is being adjusted by the gyro. Steady and constant double flashing requires re-initialization.
Ho trovato questo su Helifreak.
