aggiungo al 3d questa citazione..che così non va persa
maxbunny
Talking
Estratto dal software del Castle Link...
Punch Control 0%, Disabled No accelleration limiting. The accelleration will be 100% determined by thr capability of your battery pack to flow power and maintain voltage.
Punch Control 10% Very low accelleration limiting - good for 4wd on high traction surfaces
Punch Control 20% Low accelleration limiting - good for 4wd on high traction surfaces
Punch Control 30% Med/Low accelleration limiting - good for 2wd/4wd on med/high traction surfaces
Punch Control 40% Med accelleration limiting - good for 2wd/4wd on med/high traction surfaces
Punch Control 50% Med accelleration limiting - good for 2wd/4wd on med traction surfaces and offroad
Punch Control 60% Med/High accelleration limiting - good for 2wd/4wd on med/low traction surfaces and offroad
Punch Control 70% Med/High accelleration limiting - good for 2wd/4wd on med/low traction surfaces and offroad
Punch Control 80% High accelleration limiting - good for 2wd/4wd on low traction surfaces and offroad
Punch Control 90% High accelleration limiting - good for 2wd on low traction surfaces and offroad
Punch Control 100% High accelleration limiting - good for 2wd on low traction surfaces and offroad, very good setting for "easy on parts" style bashing.
Ci sono valori intermedi che non si vedono dal Castle Link. perche' questo è il database sorgente che serve per tutti i tipi di motori Castle..
