Originalmente inviato da galaxy guardate un pò quà.... Attachment browser: 3010B.gif - RC Groups
The following is 3010B's specifications
Input voltage range: 4.50 38.0VDC
Charge current range: 0.05 30.0A
Discharge current range: 0.05 30.0A
Maximum charge power capacity: 1000W @ input voltage 23V (500W @ input voltage 12V)
Maximum discharge power capacity: 80W
Maximum regenerative discharge power capacity: 1000W
Maximum extern discharge power capacity: 1200W @ 40V/30A
Current drain for balancing: <350mA
Balance accuracy: <10mV
Lithium (LiPo/LiIo/LiFe) battery cell count: 1-10 series (In non-balance mode, expand LiFe to 12s)
NiCd/NiMH battery cell count: 125 series
Pb battery cell count: 118 series (236V)
Battery setup memories: 10
Intelligent temperature control: Yes
PC Connect: USB port
Weight: 750g
Dimensions (L X W X D): 143X123X46mm
5.63'X4.84'X1.81'
stavolta un auto non basterà più. dovremmo comprarci un camion x andare al campo |
Grandi, grandi, grandi!
Quasi il doppio di grandezza/peso rispetto ai vari 206B e 208B comunque...
Dimensioni: 143X123X46mm
Peso: 750g
Da prendere magari insieme a questo alimentatore da 1000W:
Meanwell Power Supply Products Mean Well SE-1000-24 - 1000.8W 24V 41.7A Industrial Power Supply
Dimensioni: 278*127*63.5mm
Peso: 2,6KG
L'altro carichino da 1000W che sta uscendo è il Cellpro PowerLab 8.
Confronto delle caratteristiche:
" * 8S vrs. 10S
* PL8 has 25 presets to the 10 of the 3010B
* 3010B has a slightly larger input voltage range (4.5V-38V vrs. 10V-32V)
* PL8 has 3x the balancing current of the 3010B
* 3010B is half the physical size of the PL8*
* PL8 has 6mV accuracy and 3010B has 10mV
* 3010B can record pack temperature and halt the charge if the pack gets too hot
* PL8 can go down to 5mA charge current vrs. 50mA of the 3010B
* 3010B has built in logging memory
* PL8 has 100W internal discharge vrs. 80W in the 3010B
* The volume of the PL8 is about 1/3 electronics and 2/3 is a aluminum heatsink rated at 200W."
Possibile che il Cellpro PowerLab 8 non abbia il sensore di temperatura?
