Nominal capacity and voltage 2.3 Ah, 3.3 V
Internal impedance (1kHz AC) 8 m1 typical
Internal resistance (10A, 1s DC) 10 m1 typical
Recommended standard charge method 3A to 3.6V CCCV, 45 min
Recommended fast charge current 10A to 3.6V CCCV, 15 min
Maximum continuous discharge 70A
Pulse discharge at 10 sec 120A
Cycle life at 10C discharge, 100% DOD Over 1,000 cycles
Recommended pulse charge/discharge cutoff 3.8V to 1.6V
Operating temperature range -30°C to +60°C
Storage temperature range -50°C to +60°C
Core cell weight 70 grams
Dal databook delle A123
http://www.a123systems.com/cms/produ...NR26650M1A.pdf
-ma vanno caricate con corrente impulsiva???
-ma la tensione di fine carica 1,6v non era 2v ???
-mentre quella di fine carica 3,8v non era 3,7v ???
