Vecchio 26 marzo 10, 18:28   #18 (permalink)  Top
massimob
L'avatar di massimob
Data registr.: 03-09-2008
Residenza: Jesolo - VE
tè, incorniciati pure questa (dal manuale del Triton 2)
A built-in cooling fan helps to keep the charger cool during operation. This will help extend the service life of the charger, and allow it to function more accurately and efficiently. The fan does NOT function at all times. The fan functions (1) during
discharge, (2) during charge, if the temperature inside the charger exceeds 122°F, if the charge output power exceeds 30watts, or the charge current exceeds 2.5A, or if charging batteries which have 1-3 cells, (3) if the internal temperature of the charger exceeds 212°F it will stop all charge or discharge functions until the temperature drops below 158°F – but the fan should continue to run until the temperature drops below 113°F. CAUTION: Do not block the vent holes for the cooling fan. Failure to do so could cause the charger to overheat and possibly cause permanent damage.
scusa me ho messo in dubbio le tue conoscenze ma, sai com'è, io sono un fortunato possessore di un caricabatterie Schulze e li di ventola nemmeno l'ombra, funziona talmente da Dio che non ne necessita
Massimo Bison
https://imgur.com/a/rZMlsqz
