La castle mi ha risposto in merito a quel problema sulla perdita del "softstart", ma pur traducendolo non riesco a capire quello che vogliono dirmi....??!?
Risposta Castle Creations:
Gianluca,
If the ESC is reset at off throttle it should always spool up and the Initial Spool Up Rate. To make sure this happens every time do the following. First, update the ESC to firmware version 3.2x with out latest software version 3.251 which is a free download on our website. Then set the endpoints on your transmitter as explained the Setup Fixed Endpoints.pdf located at
Setup Instructions for CC Controllers. - RC Groups Endpoint adjustment is the same for governor mode as Fixed Endpoint.
Gli endpoint li ho regolati, ma parlano di regolazione di altri endpoint o sbaglio?
L.
