03 marzo 06, 18:09
#11 (permalink)
Top |
Data registr.: 03-02-2004 Residenza: Reggio Emilia
| 12.8v New safe technology Lithium Phosphate
4s1p
This product is much safer than Lithium Polymer & Lithium Ion, it is only dangerous when short circuited or put in a fire, as with other cells such as Nicad or Nimh.
Uses a standard Lithium charger
Features: 15C discharge rate 25C bursts
Lightweight at 42g per cell Can be discharged to 2v per cell
Saphion cells must be from the same production batch, parallelling of cells/packs by simple harness is recommended.
Specification:
Size 133 x 36 x 18mm
Unit Weight : 175gm Use: Boats, cars, planes & helicopter
Configuration: 9
Charge: 2C 2.5Amps Discharge: 18A constant, 30A bursts (e' una 1200 mah) Charge on Lithium Ion/Poly setting at 3.6/7V per cell.
2S 7.2V/4V, 3S 10.8/11.1V, 4S 14.4/14.8V, 5S 18V/18.5V
First charge at 400 mah for 3 hours Fast charge up to 2C 2.5A
Can be discharged to 5V per pack. Warning: Only use lithium charge settings. Nicad & Nimh settings will cause irrepairable damage to cells. Safety Warning. These warnings relate to ALL Lithium Polymer, Lithium Ion (Li-Po, Li-Ion) cells currently available. The fact that a supplier of Lithium Polymer, Lithium Ion
Ciao Pepitos ________________________________________________
Un ulteriore controllo prima del decollo...non guasta mai !!! |
