Salve,vorrei il vostro aiuto per migliorare i set del phoniex 80 A per il mio rex 500.
Attualmente sono scarso di potenza!! L'elicottero non ha tanta potenza e non so su che impostazioni agire, ecco i miei set:
# Castle Link Data File
# Created: Tuesday, March 16, 2010
# Do Not Edit This File By Hand
Hex55: 85
Brake Strength: 0
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 39
Direction: Forward (*)
PWM Rate: 24 Khz
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 25
Initial Spool-Up Rate: 8
Head Speed Change Rate: 8
Auto Rotate Enabled: False
Governor Mode Type: High
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 6
Vehicle Setup - Battery Voltage: 22.2000
Vehicle Setup - Gear Ratio: 12.461
Vehicle Setup - Motor Kv: 1600
Vehicle Setup - Motor Number of Poles: 6
Desired Head Speed 1: -2147483648
Desired Head Speed 2: -2147483648
Desired Head Speed 3: -2147483648
Current Limiting: Insensitive
Cutoff Voltage: Auto Li-Po (*)
Motor Timing: 10
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*)
Il tutto alimentato poliquest 6s 2500 mAh 25C
Volevo disabilitare il current limiting....
