Scusa Bi,
ti ho risposto nel thread sbagliato (l'ho messa in quello del 2° electric day):
Risposta dal forum Losi t
Since the drivers are not certified (and not correct) there is a problem installing them if you're not installing them with the Local Admin account. It's not the same as running as Admin or adding your Vista Home account as Admin, you really need to be local admin on your computer.
One way to solve this is starting the computer i failsafe mode and log on as admin. If you dont see an admin account, you need to activate it. Here's how:
Logon to Vista using your usual account.
Launch the cmd prompt - Make sure you select, 'Run as administrator'
Net user administrator password
(exhange password with your admin password selected when Vista was installd)
Net user administrator /active:yes
Restart and log on as admin.
Che vorrebbe dire: lancia il setup come amministratore, è probabile che l'utente che usi non abbia i diritti amministrativi.
Link alla discussione:
New Xcelorin Setup Software Available - Losi Forums
Link al software aggiornato:
http://www.losi.com/Content/Support/....0/SetupV3.exe
ciao ________
