Voltage for this calculation (avg):3,6075/cell with a total of 21,645
Nominal voltage: Spoolup RPM 100% throttle no governor (22,2v): 2327
Avg RPM you will see with 100% throttle and no governor: 2183
Max normal bogging applied you will see RPM at: 1929
(this number should be the minimum if your motor & battery is up for the challenge)
Spoolup with Governor @ 65%: 1961
Spoolup with Governor @ 75%: 2077
Spoolup with Governor @ 85%: 2192
non mi sembra pianino,non hai detto che c di scarica hai?comunque dovresti andare bene cosi..fai sapere
