Originalmente inviato da mircoron Dal manuale sembrerebbe di si: If at any time during the test the controls respond in the opposite direction, it may be necessary to reverse/change the direction of operation of the flight controls. Follow these steps to change the direction of the various flight controls: Be certain that the battery is disconnected from the battery lead of the 5-in-1 control unit and the transmitter is turned off. 18 19 Push down on the appropriate digital trim button on the transmitter for the control you would like to change the direction of. For example: Top elevator trim buttonelevator channel normal Bottom elevator trim buttonelevator channel reversed Left aileron trim buttonaileron channel normal Right aileron trim buttonaileron channel reversed Continue to hold the appropriate trim button while turning the transmitter on. Hold the digital trim button down for approximately five seconds, until a series of beeps/tones are heard confirming the selection.
Chi prova? ![:fiu:](/forum/images/smilies/fiu.gif) ![:fiu:](/forum/images/smilies/fiu.gif) |
Raga.. non tutti sanno l'inglese.
