Originalmente inviato da sharkmax Salve a tutti
Ho intenzione di comprare questo modello.
Sicuramente prenderò l'RTF con radio mode 1.
Allora vi chiedo:
Esiste secondo voi un qualsiasi modo per invertire il gas (leva in basso = 100% gas) sulla radio "di serie"?
Vi ringrazio in anticipo. |
Dal manuale sembrerebbe di si:
If at any time during the test the controls respond in the opposite direction, it may
be necessary to reverse/change the direction of operation of the flight controls.
Follow these steps to change the direction of the various flight controls:
Be certain that the battery is disconnected from the battery lead of the 5-in-1
control unit and the transmitter is turned off.
18 19
Push down on the appropriate digital trim button on the transmitter for the control
you would like to change the direction of. For example:
Top elevator trim buttonelevator channel normal
Bottom elevator trim buttonelevator channel reversed
Left aileron trim buttonaileron channel normal
Right aileron trim buttonaileron channel reversed
Continue to hold the appropriate trim button while turning the transmitter on.
Hold the digital trim button down for approximately five seconds, until a series of
beeps/tones are heard confirming the selection.
Chi prova?
