04 gennaio 10, 21:36
#2315 (permalink)
Top |
Data registr.: 25-11-2003
Il manuale dice: The throttle stick MUST be set in the lowest possible position, and the throttle trim must be set to the middle or a lower than middle position (the
middle position is indicated by a longer than usual beep/tone), in order
for the 5-in-1 unit to arm. The rudder stick MUST be left NEUTRAL (CENTER STICK), and the rudder trim must be set to the middle position (the middle position is indicated
by a longer than usual beep/tone), in order for the 5-in-1 unit to arm
properly
ciao |
