Discussione: Nuovo VBar 4.0
Vecchio 03 dicembre 09, 09:54   #9 (permalink)  Top
alfio76
Data registr.: 06-09-2002
Originalmente inviato da nigel_uno Visualizza messaggio
Empfänger R6007 2,4 GHz Futaba Fasst - Fernsteuerungen und Zubehör - Modellsport Schweighofer
Anche se in tedesco si capisce bene COME e DOVE può essere collegata! e costa 58,90Euro (in Europa)
A small, ultralight seven channel 2.4GHz RASST receiver for indoor and outdoor flying at ranges of up to about 300m. With serial output, ideal for controlling micro helicopters such as the TRex-250, Mini Titan, etc.
Weighs just 3.9g. A serial output at the receiver requires a special module such as the Mikado Mini-VStabi in the model, which is able to read out the signal chain and carry out the appropriate additional processing
No crystals, no frequency channel selection, and maximum possible security from same channel interference thanks to 2.4GHz FASST technology. High speed frequency hopping for best possible suppression of interference signals.
High Intermediate Frequency(I.F.) of 800MHz, making the receiver extremely resistant to “electrosmog”. Integral EASYLink button for easy binding. Can be used in seven channel mode with any FASST transmitter with six or more channels.
Specifications:
Frequency band 2.4–2.4835GHz
Frequency channels 36
Channel count 7
Channel spacing 2048kHz
Transmission system FSK
Voltage 3.3-8.5Volt
Current(mA) 40mA
Dimensions 36×21x7.7mm
Aerial length 4cm
Weight approx. 3.9g
Available in Europe in November 2009. Priced at 67,90 Euros.
Pero sembrerebbe molto adatta ai piccolini e non a quelli grossi!!!! che ne dici?
Alfio
Sono super-amico di Robertino, Volo senza motore le pale nuove, e piloto con il WI-MAX e il collegamento Direct-brain con la ricevente. Ho il Vision 50 competition e me lo hanno regalato con 249€.
alfio76 non è collegato   Rispondi citando
