io continuo ad avere gli occhi a mandorla......
allora vi dico la mia:
faccio 3d volo tutti i giorni e spacco anche parecchio.....
qusto è il mio ragioamento e cosa ne penso premesso che il mio primo modello era un trex 450 se gf originale.
ieri ho fatto un'ordine:
SKU Description Qty STATUS
GT500-051204 HK-500GT Ball Bearing 12 x 5 x 4mm 1 Reserved
HK-500-124 HK-500GT Carbon Fiber/Alloy tail s 2 Reserved
GT500-243 HK-500GT Carbon Tail Support Rod 2 Reserved
GT500-137 HK-500GT Feathering Shaft 3 Reserved
GT500-139 HK-500GT Landing Skid 2 Reserved
GT500-128 HK-500GT Main Gear Assembly 3 Reserved
GT500-104 HK-500GT Metal Flybar Control Arm 2 Reserved
GT500-101 HK-500GT Metal Main Rotor Head Set 2 Reserved
GT500-103 HK-500GT Metal Flybar Seesaw Hub 1 Reserved
GT500-126 HK-500GT Metal Tail Linkage Rod Fi 1 Reserved
GT500-133 HK-500GT Canopy Spinner 2 Backorder
GT500-211 HK-500GT Carbon Fiber Main Blade ( 2 Backorder
GT500-138 HK-500GT Main Shaft 3 Backorder
GT500-141 HK-500GT Skid Nut 1 Backorder
GT500-142 HK-500GT Tail Boom 3 Backorder
GT500-107 HK-500GT Metal Wash-out Control Ar 1 Reserved
GT500-135 HK-500GT Tail Blade 2 Reserved
GT500-136 HK-500GT Tail Drive Gear Shaft 5 Reserved
GT500-109 HK-500GT Stabilizer Bar 2 Reserved
HK5027 HK-T500 Tail Rotor Holder 2 Reserved
HK5035 HK-T500 Linkage Rod 2 Reserved
GT500-210 HK-500GT Stabilizer Blade 2 Reserved
GT500-105 HK-500GT Metal Stabilizer Control 1 Reserved
GT500-061204 HK-500GT Ball Bearing 12 x 6 x 4mm 1 Reserved
GT500-081605 HK-500GT Ball Bearing 16 x 8 x 5mm 1 Reserved
GT500-040904 HK-500GT Ball Bearing 9 x 4 x 4mm 1 Reserved
GT500-122 HK-500GT Metal Tail Rotor Control 1 Reserved
Shipment Air Parcel (Italy) up to 2.0kg $33.73
Taxes $0.00
Total $256.92
Credit Total
circa 180 euro......tutto di piu 3 corone 5 alberini 2 paia di pale in carbonio etc etc.....comprate in italia gli stessi pezzi e fatemii il conto
ora fate quello che volete.....io volo tanto mi diverto monto smonto ,...frena filetti a 1000 e giu a volare......per pochi euro
se poi qualcuno crede che sia meglio comprare batterie di marca perche la telemetria non so cosa o i pezzi originali...io sono con voi...non venite a dirmi pero che batterie turnigy o rinho non vanno bene perchè sono stronzate....
poi chi vola veramente purtroppo cade di frequente...quindi capita anche che le batterie nell'impatto si spacchino totalmente.....quindi cosa facciamo:
tu ne compri una con 150 euro e dopo un volo si rompe cosa fai? io ne compro 6....
i ricambi sono identici.....e il rapporto è ottimo
sapete quanto sono 29$ circa 20 euro....
HobbyKing Online R/C Hobby Store : HK-450 CCPM 3D Electric Helicopter Kit $29.99
