Vecchio 15 novembre 09, 15:16   #439 (permalink)  Top
pala.lberto
L'avatar di pala.lberto
Data registr.: 03-06-2006
Residenza: roma tor vergata
provato
Originalmente inviato da dex1 Visualizza messaggio
3.22 Beta 11/12/09 8.6MB
  • Added Phoenix/PhoenixHV/Phoenix ICE/Phoenix ICE HV/Thunderbird software version V3.00
  • Added Desktop icon for Graph Viewer
3.0 Beta 11/12/09 Phoenix Ice/Phoenix Ice HV
  • Significant improvements in running high inductance outrunners, smoother response
  • Added new feature to Phoenix ICE controllers allowing user to clear the data log via the throttle stick (See instructions below)
  • Better timing accuracy, higher RPM operation possible
  • Smoother transition to and from outrunner mode, some had reported this as a small dead spot in the throttle range especially noticeable during slow spool-up's
  • Bug fix. Going from full throttle to partial throttle in outrunner mode would make an audible tick
  • Big fix. Data logging frequency would vary slightly at certain RPMs
Phoenix/Phoenix HV
NOTE: Clearing Phoenix Ice & Ice HV data log
Power your controller up with your TX & RX on and set to full throttle. The controller will chime the normal power up chimes. Leave your TX at full throttle for 6 seconds after power up. The controller will emit a short tone after 1 second and then a long tone 5 seconds later. The controller will then erase the data log. You must then move the throttle stick to lowest power to arm
eccolo la.
pero siete mooolto avanti vedo.
dire che vi era arrivato l'aggiornamento nooo a bastardiii.
era un po che non mi collegavo.
provato, devo dire ottimo!!
ho messo il governor gain a medium,va molto meglio il motore è più pronto,unica pecca (forse causata dal vento)sbecchettamenti di coda,devo provare ad aumentare ancora
pala.lberto non è collegato   Rispondi citando
